Dome Light
Old Jan 3, 2019 | 09:49 AM
Bob Reed's Avatar
Default Dome Light
2004 Honda Accord EX. The driver side dome light switch stopped working. I was able to purchase the switch from aftermarket and this still did not fix the light.
I purchased another switch to ensure that I didn't have a faulty switch. Still did not work. It appears Honda only sells the entire dome housing assembly for this which far exceeds the price of the switch.
Does anyone have other recommendations?
Thank you.
More info below:
2004 Honda ACCORD SEDAN Interior Light 83250-SDC-A03ZB
Console Assembly, Roof - Honda (83250-SDC-A03ZB)
SKU: 83250-SDC-A03ZB
Replaces: 83250-SDC-A01ZB, 83250-SDC-A02ZB
I need #10
Old Jan 3, 2019 | 08:03 PM
Check fuse first,then make sure the ground is no carroded.
Old Jan 4, 2019 | 02:16 AM
mayhem's Avatar
Member
if you do need another dome light assembly , check with a local auto wrecker, a lot cheaper than buying new from dealer..I just replaced the one in my accord where the plastic inside the assembly broke apart into several pieces, and the switch just push up into the assembly not worth trying to glue back together...I got it from my local u pull it yard ,4 bucks...problem solved , I tend to think heat in the summer on the roof cooks the plastic way to much making it brittle
goinmobile
Apr 25, 2015 07:34 PM
wooddude
Jan 23, 2012 07:55 AM
cgb5208
Feb 1, 2007 11:16 PM
silverbullet
Jan 30, 2007 01:30 PM
ptonyha
Jan 30, 2007 12:05 PM
