Drivers window doesn't work
Old Aug 26, 2015 | 09:31 AM
Coolsmt6's Avatar
Default Drivers window doesn't work
The drivers window only works like once a month for a min or two then stops working till another month. All the other windows roll up and down no problem. Can someone tell me if they've had this issue and what it could be to help diagnose he real problem. Thanks
Old Aug 27, 2015 | 03:09 AM
welcome to the forum. Could be the motor bad contact or defective.
Old Oct 21, 2015 | 12:22 PM
wagonguy's Avatar
Clean the connectors on the harness. See if it helps.
If not then take your window switch apart and check / clean the contacts in it
good luck!
Old Oct 24, 2015 | 06:46 PM
Welcome in sounds like a loose connection or short in the switch.
tneilscott
Jun 10, 2015 12:31 AM
Raven
Nov 5, 2012 08:07 AM
misterix
Jul 11, 2009 05:29 AM
hotpeds
May 3, 2009 10:00 PM
VTECwarrior
Apr 11, 2009 12:56 AM
