FUEL PUMP no Buzzzz.
Old Apr 1, 2011 | 07:58 PM
mango02's Avatar
Default FUEL PUMP no Buzzzz.
1994 ACCORD. Turned on the KEY the other day and NOTHING no BUZZZ from pump and CEL would not go out while starting. CEL cycles on and off while you start I guess as soon as pressure builds up it goes out? How do you replace a pump? Do you have to drop the tank? Is there a search I can do????
Old Apr 2, 2011 | 02:47 AM
ChaseMark's Avatar
It could be a dead fuel pump or maybe even an ignition or engine problem. Try checking the timing belt to see if it's broken.
Old Apr 2, 2011 | 06:09 PM
mango02's Avatar
Re Soldered the Fuel Pump Relay and go to go. No Belt, No engine and No pump trouble.
Old Apr 4, 2011 | 07:59 AM
Glad you found the problem,how did you notice it?
Old Apr 4, 2011 | 07:50 PM
mango02's Avatar
It was Intermitent thought about the pump good thing i did a little reading first, Thank God for the internet. Try the easy cheap stuff first. Or you can try the hard expensive things and find out you screwed up.
lp284
Nov 8, 2010 12:36 AM
riverjamie
May 16, 2009 07:33 PM
Obsequious1
Sep 30, 2008 07:19 PM
katemcv
Jan 6, 2008 10:45 PM
rpankau
Jan 6, 2007 03:57 PM
