Heater Problem ?
Old Dec 16, 2010 | 01:20 PM
C_UNiT's Avatar
Exclamation Heater Problem ?
Now that it is cold I have had to use my heat every day. Positioned to high, as the car warms up the heat comes on as it should. However, several times last night after it was warm and working fine when I come to a stop, the heat will suddenly drop to a cool temperature from the vents without me doing anything to it. As I begin to drive, it will come back up to temperature. What's going on here ?
Old Dec 17, 2010 | 03:33 AM
welcome to the forum. Possible water pump getting weak, hose starting to clog or has a ristriction, or heater core getting plugged. what year and milage does our car have.
Old Dec 17, 2010 | 10:18 AM
C_UNiT's Avatar
My Accord is 2006 with about 71K on it. I also have a loud power steering issue on start up which just started happening also...I added the correct type fluid to the high level fill line, but that did not help...thinking maybe the power steering pump, or maybe this could all tie in ?
Old Dec 17, 2010 | 10:23 AM
C_UNiT's Avatar
Also, I bought this car certified pre-owned w/ 10yr/100K warranty when it had about 6K miles on it...will these items be under warranty ? How can I find out ? Thank you for your help !
Old Dec 18, 2010 | 02:44 AM
you might want to take the car to the dealer, or read the warranty and what it covers. the noisy p/s pump sounds like the pump is starting to fail. and the heater core may also be covered under the warranty. only things not covered by a normal warranty is tire ware, wiper blades, normal ware and tare items. Most mechanical is covered. heater core should not go bad so soon. Anti freeze is not normally covered.
Old Dec 20, 2010 | 10:23 AM
C_UNiT's Avatar
Thanks for your help, that's what I was kinda thinkin' I'd end up having to do...Merry Xmas !
gregk
Oct 3, 2009 03:46 AM
Brentwoodupser
Jan 22, 2009 11:41 AM
ddappete
Jan 1, 2009 09:45 PM
akaha
Nov 26, 2008 08:02 PM
stevel
Jun 28, 2008 09:48 AM
