Help! 92 accord issues.
Old Jul 27, 2011 | 10:22 PM
agresti7791's Avatar
Default Help! 92 accord issues.
Just replaced the clutch over the weekend, adjusted the pedal; everything was fine for the test drive. I went to drive it later only to break down on the side of the road. I don't know THAT much about cars, but I'm also not stupid when it comes to it.
Just for info; My tachometer was jumping all over the place and would go all the way up to 6k rpms, and not just when i was giving it gas. Mind you, the RPMs were going up, but my engine WAS NOT REVING.
I was stopped at a red light, accelerated in 1st, and all the sudden my engine died. No power steering, nothing from the gas pedal, brakes started tightening. Like I killed the car, but I didn't. Go to crank it, it cranks but doesn't turn over.
After numerous people telling me that I should change it, I replaced my ignition control module hoping that could be the fix. No luck. Now my check engine comes on aswell. I'm out of ideas! The only other thing I can think of is either a loose ground or ignition coil.
Could it be when I put the distributor back on I didn't have my lines exactly lined up? Did I miss one of my grounds? (I did end up with one extra bolt somehow that I'm not too happy about. Only I have no idea where it goes, other than not inside the tranny. I do not know what could cause all these problems, when none of these things were wrong before I replaced the clutch. And the clutch works great! I'm lost, frustrated and now broke with no car.
Sorry for the essay of a question, just trying to give a detailed view. Thanks for the help!
Old Jul 28, 2011 | 03:55 AM
welcome to the forum. check the condition of the timing belt, and check the timing marks onthe crank and cam gears.
Adam Wynn
Oct 7, 2013 02:36 PM
codymccann
Aug 21, 2009 03:17 AM
Manzyboy24
Jun 9, 2009 02:56 PM
aerykwoo
Jan 9, 2009 02:37 PM
brintonwhalen
Sep 29, 2008 05:52 PM
