HELP! 93 Accord front end wobble/noise
Old Nov 13, 2013 | 03:16 PM
nshoe09's Avatar
Default HELP! 93 Accord front end wobble/noise
Apologies if the answer is somewhere in the depths of this forum, but I have been having a wobble noise and some physical wobble coming from what I assume to be the front passenger side axle/wheel of my 93 EX. I had a 4 wheel alignment and balance done with the purchase of new tires about 2 months ago.
I thought it would be fixed with the alignment, balancing and new tires, but the noise persists. It is especially noticeable while turning, more so with left turns at normal driving speeds.
I understand this is most likely a common knowledge problem, so excuse my lack of experience. Thanks and I hope I can get some answers or ideas to narrow what the problem might be.
Old Nov 13, 2013 | 05:20 PM
lowlife9's Avatar
it could be wheel bearings or it could be your tires were not balanced properly or the weights fell of. it could also be your tires some tires are not perfectly round and no matter of balancing would help in that case. also could be warped brake rotors. or it could be warn or damaged suspension bushings. try this jack the front of your car up then grab the top and bottom of the wheel and shake it back and forth there should be no vertical movement if there is you need new wheel bearings.
Old Nov 22, 2013 | 02:41 AM
BillJackson's Avatar
Can you give us more info on the "wobble"....meaning at what speed/conditions are you feeling this at?
Old Nov 22, 2013 | 03:22 AM
welcome to the forum nshoe09. BillJackson hand-break is hand-brake
rvd123
Oct 30, 2013 04:29 AM
clutch5
Aug 1, 2011 10:49 PM
poppies18
Apr 14, 2009 03:13 PM
GreginLA
Jun 22, 2008 06:11 PM
zipzero666
Aug 29, 2006 01:27 AM
