help! 96 Accord - code P0118 -ect high input???
Old Apr 23, 2008 | 05:00 PM
deercanbrack's Avatar
Default help! 96 Accord - code P0118 -ect high input???
My 1996 Accord EX 2.2 Vtec hasits check engine light on and I can't register until I fix the problem.
The code is P0118 and says engine coolant temp sensor high input.
I have replaced both sensors and it still reads that code.
No one at Autozone or Checker or Napa could help me.
Does anyone know how to fix this or something I can try...
Any help would be cool, I'm lost and broke and can't register my check engine cursed car.
Thanks
Old Apr 23, 2008 | 11:39 PM
Default RE: help! 96 Accord - code P0118 -ect high input???
after changing the sensor,how did you get rid of the code that was put in prior to changing the sensor, and welcome to the forum.
Old Apr 24, 2008 | 06:22 PM
I disconnected the batter terminals for a few minutes and put them back on and after the drive cycle, the code came back on
Old Apr 24, 2008 | 11:24 PM
I don't think taking the battery cable off will do it, I looked this up on another honda site:- remove the 7.5 amp fuse labled "clock back up" on the passenger side. nbr 13 fuse on the box. min 10 sec, do not undo neg cable. try this,I will try to look up the info, and send you an email on how to reset/clear the code.
citytire
May 14, 2014 01:50 PM
elduderino
May 10, 2013 09:00 AM
nickaccord
Oct 22, 2010 09:04 AM
deercanbrack
Mar 13, 2008 08:26 PM
jesilp
May 24, 2007 12:50 PM
