idle goes up and down
Old Nov 7, 2009 | 06:26 PM
Titito's Avatar
Default idle goes up and down
My 91' Accord accelerates up and down by itself. This goes on for a while. Anyone have an answer?
Old Nov 11, 2009 | 04:19 AM
if at cold idle, check idle control valve, if hot check egr
Old Aug 19, 2010 | 08:50 PM
tnutz's Avatar
there are two different iac valves usualy both controlled by the temp of the anti freeze when looking at the motor u should see the two parts are atached to the throttle body (facing motor) the one on the right is the cold one the right is the hot one both can be cleaned but only the cold one can be taken apart and ajusted(careful be sure to research before just ripping into it) i'm not an expert but very thuro when i put my mind to it. any comments to this are more then welcome this is just what i have learned semi professional still an apprentice tho.
joethefro
Aug 16, 2013 03:36 PM
Red Jacket
Nov 18, 2011 03:30 AM
atrain33
Aug 4, 2011 07:05 PM
jakevv
Nov 9, 2010 11:37 PM
simorrow1987
Aug 10, 2009 02:23 PM
