Intermittent AC work
Old May 20, 2022 | 05:41 AM
vorbius's Avatar
Default Intermittent AC work
My 2008 Accord LX-P's AC is acting up. When I come to a stop cold air from AC starts blowing regular temp air and when I accelerate it blows cold. I live in NYC so I stop more then drive, LOL! Is the compressor failing? If so, can someone recommend a generic brand? OEM costs $650, out of question. I saw DENSO for about $200 on Amazon. Supposedly it's the same as the original. Is that true? Or maybe there is a remedy to this issue?
Mileage on my car is 126k.
Thanks in advance.
Old May 20, 2022 | 09:12 AM
You are likely low on refrigerant. Have it checked.
Old May 20, 2022 | 02:29 PM
C 10 man's Avatar
Banned
WOW I'm shocked you didn't tell him with all your Engineering Education his Power Modulator Valves Fuse is blown :-)
Old May 20, 2022 | 02:39 PM
You shove it where the sun don't shine.
Old May 20, 2022 | 05:39 PM
C 10 man's Avatar
Banned
WOW did they teach you that in Engineers School, I must have missed that course when I got my Diploma from Engineers School :->
Old May 21, 2022 | 12:54 AM
Thanks in advance.
Blowing cold air is likely that the compressor still works.
More likely there is another issue
Could be low on refrigerant?
Could be the AC and radiator fan is not turning on?
Could be something else I do not know about for example expansion valve?
But, I do not know. You will need to have it checked.
Please do not go jumping on replacing the compressor before doing the other checks on the AC system
If you wonder what those checks are then check youtube for information
Their videos can help you figure out what you are looking at.
Also acmech52 is (I believe is an ac mechanic).
Old May 23, 2022 | 05:21 PM
vorbius's Avatar
I added some refrigerant. Now blows even colder but still no cool air when idle. It does cool when I accelerate when stopped.
I will investigate on the Internet. I don't trust mechanics in NYC. They are all crooks. Besides I don't have time to see them. Only have Sun off and the shops are closed then.
Thank you both for the suggestions.
Old May 23, 2022 | 07:33 PM
Airflow through the condenser is low at a stop.
Old May 24, 2022 | 12:49 AM
When vehicle is moving then air flows thru the radiator and condenser thus helping to make cool air.
When vehicle is stop there is little to no air flow so the condenser can not get rid of the heat.
Would chekc the cooling fans to see if they are working
Old Jun 6, 2022 | 10:40 AM
  #10
vorbius's Avatar
Thank you all for help. The radiator fan seems to not work according to the mechanic. I will have a new one installed today. Will post the results here.
Thank you again.
