Low-miles 2005 Accord: Does this maintenance history make sense?
I have a 2005 Accord sedan, 4-cylinder, 55,000 miles. I make many short trips and consider this "severe" service for maintenance purposes, per the manual.
I take it to the dealer every 6 months for routine maintenance, which generally alternates between oil-changes only, and several-hundred-dollar maintenance packages.
For example:
Jan. 2011 31K miles -- oil change only
June 2011 34K miles -- "4 year/ 60,000 miles scheduled service" $400
Dec. 2011 38K miles -- oil change only
May 2012 42K miles -- oil change only
Dec. 2012 48K miles -- "5 year/ 75,000 miles scheduled service" $400
Jun. 2013 52K miles -- oil change only
I'll probably keep going like this. Does this make sense to you?
For example:
The last one for "5 year, 75K miles" included oil and filter change, add "Castle" oil and fuel system cleaner (?), air filter change, check and rotate tires, check brakes, adjust parking brake, replace brake fluid in master cylinder, inspect transmission for leaks, drain 3 quarts from transmission pan and replace, lubricate locks and hinges, inspect cooling system hoses and connections, inspect fuel lines. $229 labor, $161 parts.
maintentenance history makes a lot of sense. Mom has a 08 civic, has the same type of history, but less cost due to taking it to a shop that works on Hondas and less overheadl. but lots of work is done. the car runs perfect and is reliable.
Thanks for all the thoughtful responses. I like to work on cars but now I have no driveway or garage, and park on the street in the middle of a big city. I can lubricate locks and inspect hoses, but those are just part of the maintenance "packages" my dealer has, which include many more things that are harder for me to do in the street. So, I go ahead and let them do some of the easier things as part of the package.
I guess breaking down and charging for each individual maintenance service would cost more, even if I pulled out the easier items.
OhioCivicOwner
Apr 20, 2017 01:40 PM
k24hatch
Oct 15, 2013 07:20 PM
daze
Dec 8, 2006 12:25 AM
