my accord is blowing cold air through the heater. how can i get some heat?
Old Nov 12, 2009 | 12:11 AM
gonzo6580's Avatar
Default my accord is blowing cold air through the heater. how can i get some heat?
My heater won't blow hot air. it's just cold. how can i fix this?
Old Nov 12, 2009 | 01:54 AM
welcome to the forum. If this has been your car since new, check your heater valve, could be stuck closed. Go to hondaautomotiveparts.com and enter your car information and go to the parts diagram for the heater valve, it will give you the pn and where it is located ( engine compartment close to the firewall )
Old Nov 19, 2009 | 09:40 PM
josh2113's Avatar
Member
Check your coolant level. If you don't have enough coolant then you won't have heat either. And what year is this Accord? Maybe the doors in the heater box are not moving as they should you may want to check fuses. It could be stuck on A/C side. Just some more things to look into. The heater valve that ACMECH is talking about is a good thing to check as well, but I have never seen one go bad.
CrossCountryDriver
Aug 29, 2014 10:35 PM
kschjei
May 6, 2014 04:32 PM
dredreson
Jan 5, 2011 07:50 AM
ddappete
Jan 1, 2009 09:45 PM
shad9876
Sep 3, 2008 12:57 PM
