Oil on spark-plugs and wires
Old Oct 6, 2009 | 04:14 PM
gracewalters88's Avatar
Default Oil on spark-plugs and wires
I'm having troubles with my 93' Honda Accord LX. We recently changed the plugs and wires, to find they were coverd with oil.. So- we changed the upper seals, and gaskets..
But, is still leaking, causing mild mis-fires. Do we need to change the bottom seals?
At a Lost...
Please reply suggestions!
Old Oct 6, 2009 | 07:56 PM
matimar30's Avatar
Member
i just had the same problem. yes the lower seals need to be replaced. i recommend factory replacement from honda. pay a little bit more and the the good stuff. while you're at it replace the spark plug wires, dist cap and rotor also. the oil damaged my plugs. got a bosch with a lifetime warrenty from autozone for 45.99 i have a 93 accord lx with F22a1 so if its them same as yours then it's model#09830 and i also put ngk iridium spark plugs xp5224. also check the ignition module(mine is within specks but i replaced it anyways) & coils. i live in san jose.
hope this helps
gracewalters88
Oct 7, 2009 02:21 AM
popriv
Aug 16, 2009 02:22 PM
mike0094
Dec 1, 2008 12:53 AM
miket750
Jun 24, 2006 02:57 PM
miket750
Jun 11, 2006 02:19 PM
