please help i'm stuck
Old Jul 26, 2008 | 07:46 AM
cherry70's Avatar
Default please help i'm stuck
I JUST REPLACED THE CAP, ROTOR, AND COIL ON MY 1991 HONDA ACCORD EX 2.2...NOW THE CAR STARTS BUT IS VERY ROUGH AND WILL NOT IDLE CORRECTLY...I ALSO CHECKED THE TIMING BELT TO MAKE SURE IT DID NOT SLIP OR JUMP A TOOTH THAWAS FINE....I'M AT A LOSS AS WHAT IT COULD BE......
Old Jul 26, 2008 | 06:59 PM
Default RE: please help i'm stuck
welcome to the forum and enjoy your stay. are your spark plugs in good condition, are the spark plug wires tested good.Are the wires in thecorrect rotation with the firing order.Did you disconnect the wires at the sparkplugs? When pulling the wires off the cap, the carbon in the wires may have come apart.
Old Jul 27, 2008 | 06:36 AM
cherry70's Avatar
thank you for the respone...it turned out that the distrubtor needed to be replaced the gear inside was all screwed up.....
Old Jul 29, 2008 | 02:36 PM
thank you for the reply of the good fix.
hackingwood
Mar 23, 2014 05:16 PM
pandong
Sep 20, 2007 10:06 PM
theokengineer
Nov 25, 2006 10:46 PM
wb925
Oct 30, 2006 04:02 AM
Hannu
Sep 28, 2006 02:43 PM
