Window Stuck
Old Oct 3, 2006 | 01:51 AM
theokengineer's Avatar
Default Window Stuck
I have a 1987 Accord and the drivers power window is stuck. The window was making a grinding sound like the gears were striping, but now it makes no noise and won't move. The other windows work and I have checked the fuse. I have the inner door panel off, but was wondering how to get the window motor off. Do I have to take off the regulator? Does anyone know of a website that shows how to take these off? How to lower the window to remove the bolts holding the glass to the regulator? Thanks for your help.
Old Nov 10, 2006 | 01:31 PM
H4AFY's Avatar
Default RE: Window Stuck
Hi did you get this sorted
Old Nov 15, 2006 | 10:51 PM
93accord's Avatar
I'm not sure how you would go about lowering it. You might be able to loosen the whole regulator assembly and gain access enough to remove the glass. The regulator will not move with the motor attached (at least I don't think so) and I doin't think you can get to motor mounting bolts with the regulator in the door.
Old Nov 25, 2006 | 10:46 PM
go to autozone.com, register for free, put in your car info, go to vehicle repair guides, to body and trim, to door and regulator and it will show and instruct you how to do the regulator and motor fix.good luck
pandong
Dec 9, 2007 05:30 PM
pandong
Sep 15, 2007 03:27 PM
73Charger
Jul 18, 2007 09:55 PM
wb925
Oct 30, 2006 04:02 AM
Hannu
Sep 28, 2006 02:43 PM
