Power window
Rear passenger window 96 accord does not go down when operated by the master switch. It works fine at the door switch. It does go up from the master switch, but not down. Also, the front passenger window will only lower from master switch, will not raise back up. Switch on door works fine. These problems did not start at the same time. Bought used about a year ago with front passenger window problem. Back seat window problem just started a week ago. Thanks.
Jiggled and applied a little pressure on master switch for back seat passenger side window. Started working. No change doing the same for front passenger side window with master switch. Any feedback much appreciated. Thanks
