Power window
Old May 18, 2018 | 09:26 AM
Dmil74's Avatar
Default Power window 96 accord
Rear passenger window 96 accord does not go down when operated by the master switch. It works fine at the door switch. It does go up from the master switch, but not down. Also, the front passenger window will only lower from master switch, will not raise back up. Switch on door works fine. These problems did not start at the same time. Bought used about a year ago with front passenger window problem. Back seat window problem just started a week ago. Thanks.
Old May 18, 2018 | 11:29 AM
Dmil74's Avatar
Jiggled and applied a little pressure on master switch for back seat passenger side window. Started working. No change doing the same for front passenger side window with master switch. Any feedback much appreciated. Thanks
Old May 19, 2018 | 01:23 PM
welcome to the forum. might try a good used master switch from a salvage yard, or ebay. seems the master contacts are weak or dirty
Old May 19, 2018 | 07:41 PM
I agree,worn or dirty contacts,new switches should prove to be the answer.
drew and not u
Jun 25, 2023 11:13 PM
93accord
Aug 3, 2009 12:07 AM
nelpasa
Mar 9, 2007 11:02 PM
han_doi
Nov 18, 2006 02:52 AM
jsachen
Jun 10, 2006 01:39 PM
