Slow to finally start with check engine light coming on
Old 04-21-2018 | 04:46 PM
Luxoride91's Avatar
Default Slow to finally start with check engine light coming on
Hello, my ' 91 auto Accord has 120k miles on it. Lately from a cool start (above freezing temperature and after sitting overnight) it takes longer cranking until it starts, then sputters a little before smoothing out at idle. The yellow check engine light comes on too. If I immediately turn it off, it restarts normally and the check engine light does not come back on. Does this sound like the Engine Control Temperature (ECT) failing? My guess is that It's the original sensor to the car. At around $115.00 from the Honda dealer I'm thinking of just replacing it. Or, can anyone comment on aftermarket parts quality on ECTs from their own experience?
As stated for other year model threads, there's also a sensor under the distributor cap? I'm a little confused as to why a temp sensor would be located there for engine temp, maybe someone can help explain? Should I also consider replacing this? Thanks in advance for this handy forum and folks taking the time to help each other out.
latinpio
06-05-2014 04:37 AM
Rich0591
09-09-2009 03:33 AM
sucmanh
08-12-2008 12:42 AM
sucmanh
08-12-2008 12:39 AM
Quick Reply: Slow to finally start with check engine light coming on
