Spark Plug Recommendations
Old 12-23-2009, 01:37 PM
You can buy a tool called a boot puller,not expensive,or you can try twisting the boot instead of pulling ,that may break it loose,anyway when you do get them off, spring for a new set and like Matimar30 said use the grease.
  #12
Old 01-01-2010, 03:09 AM
matimar30's Avatar
Member
if you need anything besides your hands to take out the plug wires then you'll prob end up buying new wires. a pair of pliers works too and it's prob part of your tool bag as well. ^_^
at that point you might want to spray a little wd40 to loosen it up. just clean all that up up before taking out your plugs and putting on new wires, otherwise it'll end up in you cylinders.
save some money here and use it for better parts later.
  #13
Old 10-24-2012, 09:41 PM
xsimonx's Avatar
I know im late with this but just wanna share this one. I want to recommend this one because for me it works perfectly fine and my friend just recommended it to me. So far im not having any problem though. Most of people i think use this one and ngk. Just check it here: Bosch Super Plus Spark Plug
  #14
Old 10-25-2012, 02:56 AM
lowlife9's Avatar
bosch is complete garbage to use in a honda just to let you know if this isn't just more spam that is which im fairly certain is.
  #15
Old 10-28-2012, 08:45 PM
xsimonx's Avatar
well i dont know but it works fine with mine and i respect your opinion but please be considerate when posting your reply mate.
  #16
Old 10-31-2012, 11:22 PM
lowlife9's Avatar
its not my opinion its a fact that hondas require either NGK or DENSO plugs so stop spamming mate.
  #17
Old 11-08-2012, 01:28 AM
matimar30's Avatar
Member
dang.. i can't believe this thread is still going..
If you want a stock replacement the ngk v-power copper works just fine at 2.29 each.
If you want something a little better then spring for the ngk iridium like i stated b4 and it's only 6.99 now.
Plug Wires. go with bosh cause it has a lifetime warranty and its 39.99.
so take your pick it's your car.. all these prices are from autozone here in california.
still cant believe you people are still taking about this.. lol
  #18
Old 11-08-2012, 03:37 PM
lowlife9's Avatar
03s don't use wires.
  #19
Old 11-09-2012, 12:08 PM
matimar30's Avatar
Member
just looked it up.. duh.. my bad.. the coil is build in into to plug so it's a 1 piece. it looks like there's a bolt holding the coil inplace.. hope you know that? maybe that's why it's not coming off. lol. it's listed at 44.99 each and only a 2 year warranty at autozone. and since yours is a 6 cyl. it'll add up quickly if you replace all 6 of them. i was thinking if my 93 accord. good old f221a motor. i'd test it b4 you purchase it.. so that you only buy if yours is bad.
  #20
Old 11-09-2012, 02:23 PM
lowlife9's Avatar
the coil packs are separate from the plugs not built in. they rarely need replacing but you wouldn't want anything but honda which i believe isa DENSO product. you can find them used at car yards fo cheap.
rons97accord
03-22-2009 09:25 PM
Mag Auto Parts
11-13-2008 12:27 PM
LizzieWartooth
09-03-2008 10:10 AM
rude_lude7
08-26-2007 04:09 PM
Sparkplugs.com
12-01-2006 03:12 PM
Quick Reply: Spark Plug Recommendations
