Starting problem
Old Feb 12, 2020 | 12:26 AM
Angiuano58's Avatar
Default Starting problem
I've been having this problem for almost 2 years. When I think it's getting better it starts again. I've had mechanics test the charging and everything checks out fine. Sometimes it will start other times it won't. I never know whether it will start. I happened to be speaking with an operator from USAA and she mentioned that she had been having the same problems with her 2016. Mine is a 2013.
Old Feb 12, 2020 | 02:25 AM
on the earlier model accords, the distributor coil gets hot, and doing a visual check you can see the hot spot. this will cause a no start when warm or hot, after cooling down engine, it will start and be good until the next hot shutdown.
Old Feb 12, 2020 | 11:01 PM
Not enough information to even guess at where the issue lays.
Is this an intermittent no crank, no start??
Or is it an intermittent crank, no start??
When does it happen? Hot or cold??
What has been done to find the issue??
troyflake
Feb 12, 2020 11:13 PM
ratlhed
Sep 30, 2013 12:48 PM
Loco Ken
Oct 28, 2011 01:06 PM
Jeffvk
Oct 21, 2011 09:50 AM
jonathanteller
Sep 18, 2010 01:17 PM
