transmission cooler
Old Jan 21, 2020 | 04:06 AM
mayhem's Avatar
Member
Default transmission cooler
was told by a retired Honda mechanic that I should replace the stock trans cooler( I don't even see a cooler ) with a bigger better unit... has anyone done this ? if so what would be the size needed ? is it a pretty clean cut install ? I've know for years that heat isn't a good thing for a transmission..i just thought the stock cooler would have been good but from what he tells me , not so... by the way 99 accord 2.3
Old Jan 21, 2020 | 07:02 PM
your current trans cooler goes thru the bottom of your radiator, so it is at least water temp hot. you can get small size depending on what you intend to haul. but i have a 12' X 12" trans cooler on my 87 motorhome 454 with a 400 trans. and it is good to haul up to 5k lbs all day. you don't need one this large. and you can mount it up front of the a/c condensor and use proper rubber hose for inlet and out let hooked up to your existing metal lines. try to place a screen in front of the cooler to prevent rocks from hitting it,.
Jeremy Luallen
Aug 11, 2019 06:03 AM
Ugh3012
Apr 30, 2019 12:58 PM
Twiztedchevy
May 30, 2018 05:33 PM
ZachRidgeline
Jan 25, 2018 03:23 AM
Donkeydawn11
Feb 9, 2012 10:37 PM
