Valves and Accords
Old Mar 31, 2009 | 08:55 PM
mike0094's Avatar
Member
Default Valves and Accords
how are you supposed to determine whether your valves need adjustment?, i mean, the engine note a honda emits makes it a real challenge(early 90s accord) to distinguish normal sound from abnormal noise..is there any sound/noise in particular a honda with poorly adjusted valves would make and at what rev range or engine temp? any info would help
Old Apr 1, 2009 | 03:28 AM
i could hear my valves noisy at idle, at higher rpms there is too much noise besides the valves. Also I have stethoscope and i can hear it good. Also opening the oil fill cap, the loose valves can be heard.
Old Apr 20, 2009 | 08:30 PM
fuji576's Avatar
My accord wont start. There was 2 extra quarts of oil in theyre that the person I let use the car put in theyre. I took off the valve cover and the 3 end valves towards the front (drivers side) in the head makes a loud clicking noise while flicking oil. It almost starts but just not enough compression to do so, I think the answer lies in the valves which some guru can guide me to the light because rarararararrarararrara "what chewbacka says" . Any advice. I dont wanna swap the whole motor if its something small like a bent valve or something like a bolt in theyre, I dont think so though. Any advice? Can I just adjust the valves till it doesnt flick/click anymore
Old Apr 26, 2009 | 10:24 PM
fuji576's Avatar
Default Update
Guess what ****ers?, I ended up changing the head and I found 6 bent to hell rods in theyre (all exhaust). We now all know what causes bent rods thanks to me (too much oil). So if any of you folks have symptoms such as sticking rods you all know that too much oil causes hydrostatic pressure and bends up your rods. Just like how water doesnt compress so when it goes in your engine it blows your rods, crank, etc. Too much oil slowly tweeks your major components. I guess im gonna have to tell my beautiful wife/girlfriend not to try and work on the car without permission. Im still having issues though. After putting the new head on, it clicks a little. Still not drivable in my book. Any advice to fix it? Its alot better but I would say about 80 percent. I want it 100 percent better. Oh yeah and my main belt wobbles. It is more loose on one side than the other.
kingk788
May 26, 2010 06:02 AM
Organik
Apr 16, 2008 07:56 PM
ThomasD
Jul 11, 2007 12:11 AM
Plus
Jun 1, 2007 10:15 AM
ibill32
Jun 22, 2006 04:21 PM
