Vibration when braking
Old Jan 12, 2009 | 07:03 AM
ady5179's Avatar
Default Vibration when braking
My car Honda Accord 2.0 SM4 CB3 model 1991.WhenI brake mycar steering vibrate. I was change original brake pad, skin the brake disc (in range not over limit),change the brake piston kit,both tie rod,shock absorber,tyre, drive shaft external left.During tyre changing I do alignment, tyre balancing. Can anybody tell me?
Old Jan 12, 2009 | 11:41 AM
Default RE: Vibration when braking
when you say skin the brake disk, I take it to say the disk/rotor was machined flat/ or trued, ( back to perfect new?) If the disk is true, the brake pad is new, jack up one side of your front wheels and have someone place in gear to rotate the tire and see if the rim or half shaft is warped or cv worn. besure to place chocksin front and back of all wheels on the ground incase the opposite wheel pulls a bit the car will not fall of the jacks.
yrk
Oct 20, 2009 02:37 PM
Flying Grape
Jun 18, 2009 10:19 AM
derekcentrico
Jun 5, 2009 06:28 PM
iep
Apr 22, 2009 05:00 AM
roses15534
Dec 9, 2007 05:43 PM
