Weird Acceleration Jerk
Old Jan 11, 2010 | 11:37 AM
Rajiv's Avatar
Default Weird Acceleration Jerk
Hi All, Help needed seriously...
My Honda Accord Inspire 1994, changed my engine a year back. I had this jerky shift from the beginning but mechanic said its my engine and tranny mount I was fine with it until recently I found this weird shaking while acceleration sometimes its like around 40-50 kilo and nothing when i reach 120 but somethings is from 0. If i turn of the engine and start again everything is fine for a while and it comes back again. Changed my tires, suspension worked with new CV joint and bearings so nothings wrong with my suspension.
I'm having break servo (break peddle harden and soften now and then) issue and also my tranny fluid is a bit high can this cause the problem. Please tell me that its not my tranny or the engine....
When I turn my engine off the break peddle soften and car runs fine then when its hard again the jerk also comes back but I cant relate this to together.
Can the transmissions gas cause this, I have no clue whats going on. HELP PLEASE!!!!
Old Jan 22, 2010 | 12:57 PM
rebelagent's Avatar
I had a 91 honda accord that had a similar problem minus the break. Found out that all i needed was balancing/alignment/and a new tire. I didn't believe it until they did it. The jerk went away. When was the last time you had the balanced?
When my car was going about 40+ you'd feel a jerk then again at 50 and 60. They also said it wouldn't hurt to check my tranny to make sure it was properly mounted. Which it was.
BetsDancer
Apr 6, 2014 04:32 PM
rebelagent
Nov 30, 2009 11:10 AM
a_l_e_x1
Jun 14, 2007 03:06 AM
Rob
Jan 9, 2007 02:17 PM
ALLm0t0r
Nov 18, 2006 01:57 AM
