Won't start when engine is warmed up
Old Feb 13, 2016 | 10:48 AM
classy_gene's Avatar
Default Won't start when engine is warmed up
Hello, I'm new to this forum. Thanks in advance for the help. I recently bought a 1997 Accord 4 cylinder. The car starts and runs awesome until you try to re-start it while the engine is still warm. Sometimes you have to wait 4 hours till it will re-start. I have replaced the Main Relay under the dash based on it being a possible cause. So I'm down to ignition coil and distributor? How does one test the distributor? Can a coil function when it is cold but not hot?
Thanks for the info
Old Feb 17, 2016 | 07:36 AM
welcome to the forum. go to troubleshootmyvehicle.com it may help you to check what you need.
Old Feb 18, 2016 | 08:59 PM
Thanks, I pulled of the distributor cap and it is in really bad condition. I'll start by replacing it.
Old Feb 21, 2016 | 09:19 AM
Your starter relay my be bad,I have seen this problem before,when they get hot they seem to lose contact.
Old Feb 21, 2016 | 06:48 PM
The engine turns over fine, just wouldn't start. I replaced the ignition switch today since it seemed to start better if you wiggled it around.
ultimatesalmonslayer
Sep 17, 2017 05:50 AM
Chris Skoglun
Jun 27, 2016 06:46 PM
sssmasss
Jul 21, 2011 03:57 PM
diamonddelts
Nov 1, 2009 11:22 AM
Metman2J
Oct 6, 2006 03:28 PM
