'01 civic ex V Tech problem, help please!
Old Aug 18, 2008 | 09:17 PM
poetntheprocess's Avatar
Default '01 civic ex V Tech problem, help please!
I've had my Civic for about 4 years now, no big problems except recently as in the past 1.5 years during long commutes especially up hill. I've found the problem happens at exactly 400rpms, my engine sputters until I take my foot off the gas and get under 400rpms. I talked to my Honda only mechanics and they said they can't do anything about it, but I can't wrap my head around the fact that there is nothing to be done and I've never heard of this happening before. Please help if you can, anything at all would be appreciated.
Thanks
Old Aug 19, 2008 | 02:41 AM
andry's Avatar
Member
Default RE: '01 civic ex V Tech problem, help please!
any help? i supect to the fuel pump.
Old Aug 22, 2008 | 04:58 PM
welcome to the forum and enjoy your stay. would like to know when your last tune up was, and what was done.Also check the fuel pressure in your fuel rail. what is your current milage? Air filter clean? Can the car go above 4000 rpm's. ( you state 400 rpms, this is below idle )
Old Aug 24, 2008 | 05:12 AM
andry's Avatar
Member
please update to us if your problem fixed, thanks.
Old Aug 29, 2008 | 08:12 PM
EkblackB18's Avatar
it def.... sounds like a fuel problem....i would check everything fuel related...pump...regulator...rail...injectors.etc. .... it sound like when ur car is on a slant it starts fuel cutting......what happens when you go down hill..anything?...
Old Sep 3, 2008 | 10:07 AM
c3o5nnect's Avatar
I suspect and air/fuel problem as well. Make sure your fuel system is operating properly, and maybe check a few sensors.
Old Sep 6, 2008 | 07:51 PM
Hey sorry I have not posted in return. I just moved into a new place so its been an adjustment. It was at my last checkup when I told them about the problem (at an all Honda place that was recommended to me) and they said that everything looked fine and they had no idea what was going on so nothing could be done. I can go above 4000rpm(4000 and not 400rpm is what I meant in the original...I have an issue with proof reading as you can see) but after driving for a while is when it gets worse. I'll check on the fuel idea, see how up to date I am with all of those, my air filter is fine. My mileage is 124 thousand give or take.
#1moe
Apr 17, 2013 04:07 PM
RdRcr150
Dec 19, 2007 08:38 PM
theuniqueartist
Jun 13, 2007 06:41 PM
drunkenmunkey
Jun 5, 2007 11:10 AM
drunkenmunkey
Jun 5, 2007 11:01 AM
