02 civic problems
hi everybody, new to the forum and got a couple questions.. I got an 02 civic that's always blowing a fuse for the passenger side windows.. Faulty window switch?or maybe a short? and also the check engine light is on and here are the codes:
P1298:Electrical Load Detector Circuit High Input
p1509:IAC Valve Circuit Failure
po113:Intake air temperature circuit high input
po118:Engine coolant temperaturecircuit high input
Thanks
bruce
Thanks
bruce
welcome to the forum, have you checked the motor for proper operation and the switch and lines for a short. after fixing the window problem, clear the codes and run again and check to see if the same ones come up or different ones show up.
