02 civic problems
Old Oct 25, 2008 | 04:07 PM
hondaguy's Avatar
Default 02 civic problems
hi everybody, new to the forum and got a couple questions.. I got an 02 civic that's always blowing a fuse for the passenger side windows.. Faulty window switch?or maybe a short? and also the check engine light is on and here are the codes:
P1298:Electrical Load Detector Circuit High Input
p1509:IAC Valve Circuit Failure
po113:Intake air temperature circuit high input
po118:Engine coolant temperaturecircuit high input
Thanks
bruce
Old Nov 17, 2008 | 11:11 PM
Default RE: 02 civic problems
welcome to the forum, have you checked the motor for proper operation and the switch and lines for a short. after fixing the window problem, clear the codes and run again and check to see if the same ones come up or different ones show up.
Old Dec 3, 2008 | 06:12 AM
Himanshu's Avatar
i had the same probleme b4 some days, civic ex 1997 manuel 4 doors, i change
the alternator with no result,
Thank you.[&:]
Old Dec 8, 2008 | 02:23 AM
909civic's Avatar
i had the same problem with my 02 lx. the p0113 is possible a bad sensor if that does not fix it then its is a possible problem with the connector or the wires
