10 Civic LX Horn Broken
Old Jun 21, 2017 | 12:06 PM
jboxford's Avatar
Default 10 Civic LX Horn Broken
Bought a 2010 Civic LX and the first day the security system went off with lights flashing and horn honking until I got to a mechanic who showed me the disable procedure (lock-unlock the door) which stopped the alarm, but now the horn doesn't work, which won't be good when I go for inspection. The fuse under the hood checks out, and other than trying to reboot the electronics by disconnecting the battery, I don't have a clue. Any other ideas much appreciated.
Old Jun 22, 2017 | 07:46 AM
welcome to the forum. if you can find out the the maker of the alarm sys, you might call them and see if you can get a wire diagram to put the horn back to original if you are not using the alarm. sometimes there is an inline fuse near the battery.
Old Jun 28, 2017 | 07:52 AM
jboxford's Avatar
Checked the fuse, hear a clicking from the relay switch in the fuse box when I press the horn, so I know both those work, removed the horn and wire it to the battery and it blows! So while I contemplated jerry-rigging a separate circuit with a switch on the dash for the horn, I figured I should give my stupid reboot idea a whirl, so I disconnected the negative terminal of my battery, reconnected it, and voila! My stupid idea worked, horn works fine.
Dear Honda engineers, please keep the horn on a separate circuit! I need a horn, not your silly theft protection idea.
Sincerely,
New Honda Owner
Old Jun 29, 2017 | 02:45 AM
Thanks for the feed back and fix, and yes all car horns should have a separate circuit from the alarm or override.
bushfan65
May 18, 2010 01:31 PM
rufryder
Feb 6, 2010 02:31 AM
maineduckhunter
Jan 16, 2010 03:12 PM
Stillwater Sky Blue Insight Owner
Jul 6, 2009 09:59 AM
JayJay
Aug 20, 2007 11:46 AM
