1985 1.5 oil pan gasket
Old Nov 26, 2017 | 01:41 PM
crash_x's Avatar
Default 1985 1.5 oil pan gasket
Hi all, Having a hard time sealing oil pan. On and off about 6 times with no luck. Torqued to 9 inch pounds as to spec. I pulled drivers side axle for more room. Having a hard time at the flywheel end mostly. Has anyone tried just RTV? Please help, the price of oil is killin me. Thanks, Crash_X
Old Nov 26, 2017 | 04:28 PM
welcome to the forum. I have always used a lite coat of rtv when replacing gaskets, very light coat on both sides of the gasket, time consuming. also need to make sure the pan or cover surface is flat, they have a tendency to get warped at the bolt area due to tightening.
Old Dec 3, 2017 | 03:02 PM
Welcome in,my thoughts was warped pan myself,you may have to replace the pan if RTV won't correct the problem.
Hondagal1
Sep 20, 2013 11:50 AM
Marc
Dec 6, 2012 10:18 PM
ajaybali
Apr 12, 2010 02:12 AM
Murok
Jan 18, 2010 05:19 PM
samanthaxxx
Jul 25, 2007 08:07 PM
