1996 honda civic ex d16z6 manual swap in limp mode?
Old Jul 1, 2022 | 11:50 AM
d16z6's Avatar
Default 1996 honda civic ex d16z6 manual swap in limp mode?
i just bought the car with the swap installed and it would crank but not start. i pulled spark plugs and they were wet and had a lot of carbon build up. the oil was a little over filled so i changed the oil cleaned the spark plugs and it ran. it blows white smoke and acts as it’s in limp mode . will only go to 4,000rpms and hits rev limiter. looks like the previous owner put all new distributor, plugs, injectors , fuse box , wiring harness, ecu, fuel pressure regulator/gauge. i don’t know if i just need a tune and maybe new head gasket. i really have no clue what i’m doing just need some pointers in which direction i should go.
Old Jul 1, 2022 | 02:01 PM
White smoke. Does it smell sweet? What is the coolant doing?
Old Jul 1, 2022 | 04:49 PM
d16z6's Avatar
it smells like oil&gas. and the coolant at first drained 2 times but it’s staying full now
Old Jul 1, 2022 | 07:38 PM
What do you mean? leaked out? Are you using antifreeze?
Old Jul 1, 2022 | 08:23 PM
d16z6's Avatar
no, there wasn’t any coolant leaks. and yes i’m using antifreeze/coolant.
do you think the timing could be off with the air/fuel ratio making it not go above 4,000rpm?
Old Jul 1, 2022 | 09:03 PM
I think the first thing you need to do is to fix a bad head gasket.
ColtonN
Feb 19, 2016 02:29 PM
charliezx2
Jun 12, 2014 09:57 AM
yogibear27804
Dec 1, 2013 07:12 AM
hondaman
Jul 11, 2008 09:04 AM
sleepers rule
Apr 8, 2008 05:00 PM
