2001 Honda Civic EX Master brake Cylinder help Needed
Old Apr 17, 2010 | 01:13 PM
kink_27565's Avatar
Default 2001 Honda Civic EX Master brake Cylinder help Needed
I have to cahange the master cylinder rotors and calipers on my civic, I have already completed the pads, rotors and calipers but i am still waiting on the master cylinder to get here, what exactly do I have to do when i get the master barke cylinder in? Do i just have to bolt it up add fluid and bleed the brakes??? Or do I have to have some shop adjust the booster? The booster was not the problem and it was working fine before. The problem was the diaphragm in the master cylinder that tore and then the front left brakes were locked up after i would drive for a couple miles. Please help with any suggestions or prior experience with this.
Old Apr 20, 2010 | 02:37 PM
welcome to the forum. Sorry no prior experience with this. but after changing the master cylinder, find a diaphram type pump or a direct pump that will not allow any air into the system and bleed your brake backwards from the brake cylinder, this will take air out of the system into the master. be aware the resovoir will fill up and needs to be drained or sucked out. a turkey baster can suck out fluid good. doing this with the farthest cylinder first also places clean fluid into your system.
stook00
Feb 21, 2017 04:17 AM
hondaridnlow07
Aug 26, 2009 10:55 AM
asky71
Jan 19, 2009 08:28 AM
Dmanx1030
Dec 30, 2008 09:42 PM
J2Performance
Jan 15, 2008 02:19 PM
