2001 Honda Civic Timing Belt?
Old Jul 21, 2019 | 10:23 AM
sunnysioux's Avatar
Default 2001 Honda Civic Timing Belt?
If you are reading this, thank you for your time. Any suggestions/comments would be helpful.
Yesterday I was driving my car in town, 2001 Honda Civic EX, going about 25 mph. Heard a clunk, almost sounded like I had hit a small rock, then battery light and oil light came on. I tried to accelerate, car didn't respond. Lost all power, coasted and was able to make it to a side road safely. The car will turn over but won't start. Lights turned on. Battery is okay. Checked the oil, almost empty. This is obviously a problem. Previously over 6 months ago, I was losing a bit of oil and we replaced the valve cover gasket. That seemed to have fixed the issue. I am not due for another several hundred miles for servicing. No, I hadn't recently checked the oil and I know better not to go for so long without checking it and it could have been easily preventable. A+ for being an idiot!
No knocking or squealing was heard. No check engine/oil/battery lights came over before incident. Temperature gauge was normal. No Smoke. Nothing. Was running just fine, no signs that there was anything wrong.
I had taken the car the day before, over 200 miles and had it up to 70 mph. Was running like normal.
I could have two separate issues here. Oil issue and the issue of why it is not starting. The timing belt seems very likely.
Any suggestions on what to look at, test. etc would be very helpful.
Thank you.
Old Jul 21, 2019 | 07:00 PM
Open the oil filler cap on the valve cover
Shine a light onto one of the valves
And have someone crank the engine for a couple of seconds
Does the valve move?
If not then most likely timing belt broke
If it does move then check for spark and injector pulse
Old Jul 22, 2019 | 03:50 AM
welcome to the forum. if you have over 120k miles on the same timing belt, or over 5-7 years, it may be the timing belt. if you take your timing cover off, you can check to see if your timing belt is damaged or jumped a cog. if you cranked your engine over with the timing belt broken, you may have broken your engine by smashing the pistons into your valves. Honda has a 0 tolerance on piston/valve clearance. only the fords have piston valve clearance in the event of a timing belt failure. report back to to advise us if your timing belt appears to be good, also your milage. I use to own a 02 dx 300k + miles and given away, still running.
Littleheather
Dec 2, 2015 04:40 AM
jmurphnd
Dec 6, 2010 07:28 PM
coloradocivic
Jul 10, 2008 06:45 AM
dcoperator
Jan 6, 2007 03:37 PM
Xoxo97AccordF22bXoxo
Sep 28, 2006 01:56 PM
