2005 Civic 1.7 - cranks but will not turn over
Old Dec 9, 2019 | 05:08 PM
jvmagic's Avatar
Question 2005 Civic 1.7 - cranks but will not turn over
Hi,
My 05' Civic quit on me on the freeway and it won't turn over. The code pointed to the crank sensor which I replaced (purchased via amazon; Beck Arnley 180-0393) and the car still does not turn over.
I removed the oil cap and when the car cranks I can see the internals moving (cam) which I believe is a good sign.
What else do you guys suggest? There are no current codes as they were erased as I disconnect the battery while replacing this sensor.
Thanks in advance,
~JV
Old Dec 9, 2019 | 06:38 PM
Back to basics.
Check for spark
Check to see or hear if fuel pump is running
Check for clogged exhaust
Check for injector pulse
etc.
Old Dec 9, 2019 | 10:01 PM
welcome to the forum. visual check to see if the timing belt jumped a tooth ...
Old Dec 10, 2019 | 12:33 PM
jvmagic's Avatar
Thanks for your input. Will it be obvious upon removal of the timing cover?
Old Dec 10, 2019 | 05:50 PM
It will be obvious if you know what to look for
Otherwise, it all looks the same.
niram2582
Jun 14, 2012 08:38 AM
truettb20a
Feb 27, 2011 05:33 PM
92Ricer
Sep 1, 2009 07:06 AM
97_built
May 12, 2009 01:49 AM
ttim
May 3, 2008 09:53 AM
