91 Civic Reverse Grind
Old Jun 13, 2006 | 09:05 PM
joejocrazy's Avatar
Default 91 Civic Reverse Grind
I have a 91 Civic Coupe Manual. All gears are working good and the clutch seems fine although when I put it into reverse either slowly or fast it grinds pretty badly. What could be the problem?
Old Oct 5, 2006 | 03:00 AM
rob11059's Avatar
Default RE: 91 Civic Reverse Grind
Well you should be able to get it in but i know that on alot of honda's it is a pain some times and doesnt seem to go in or goes in but seems to grind but try to go forward first then pull it in reverse and slowly let the clutch out, if your new to honda youl eventually get the hang of it
good luck
Old Oct 5, 2006 | 05:04 PM
mononokifool's Avatar
yeah pretty much all hondas have difficult reverse. i have a '91 also but it never grinds i do have a new clutch but it is sometimes hard to get in, all i have to do is let out the clutch a small bit and it slips right in
bachiach
Mar 2, 2014 08:45 PM
duncan69
Feb 5, 2010 01:40 AM
mike0094
Jan 10, 2009 08:55 PM
a553487
Sep 18, 2008 06:29 AM
flawless03
Dec 19, 2007 05:12 PM
