93 civic ex running like crap
Old Jul 19, 2009 | 08:06 AM
dawgs3347's Avatar
Default 93 civic ex running like crap
its getting plenty of fuel. we replaced the distributor, cap, rotor, plugs and wires to no avail. it idles really rough and when you tap the gas, it hesitates then drops to dangerously low rpms. if you're driving down the road and come to a stop it will stall. no idiot lights are on. i'm completely stumped on this one. any help would be greatly appreciated.
Jake
Old Jul 19, 2009 | 07:07 PM
ASar's Avatar
open up, ur collant over flow tank run the car if it starts boiling up and coming out after a few minites ur leeaking compression and need a new head gaskit, if not cheack ur intake manifold for leaks and check for vacuume leaks, grab some carb cleaner spray it on one hose at a time while its running if it surges or rpms dropp, (ull hear it) that hose is leaking
Old Jul 30, 2009 | 12:36 PM
BigPip's Avatar
Could be bad gas. Add some water remover and see if that helps. I had a similar problem happen to me a few years ago, after I got new gas in it the problem went away. But that wasn't until after a complete tune up and many other new parts.
Old Jul 30, 2009 | 09:17 PM
91haydenSI's Avatar
another possibility could be your PCV valve or an idle air control valve. r
Way2big
Feb 14, 2013 06:49 PM
andrewporter
Aug 30, 2012 11:01 AM
andrewporter
Aug 27, 2012 05:42 PM
AcuraPartisan
Nov 23, 2010 03:52 PM
AcuraPartisan
Nov 23, 2010 03:51 PM
