96 civic just died...
Old 07-30-2009 | 12:44 PM
BigPip's Avatar
Default 96 civic just died...
I got in my car the other day, started it up, drove up to the mail box, got back in my car and went to leave. I got to the stop sign and as I started to leave the car die. No signs of trouble previous to this.
I KNOW- the fuel pump is working and it is getting fuel and I also know that it is NOT getting spark. This leaves me to believe it is something in the distributor.
Does this sound more like a coil going bad or an Ignition Countrl Module?
I suppose when I get a free chance I can check the coil for the ohm output but I don't know when that will be.
Old 07-30-2009 | 10:19 PM
91haydenSI's Avatar
depending on where you are get the car running and take it o an advance, o'rileys or wherever get them to do a full load test and they can tell you where your problem is coming from in about 2 minutes.
Old 07-31-2009 | 03:31 AM
Also check to make sure the belt is still in good condition. And the coil/ignitor is probably going bad. Make sure you have power into the distributor also.
Old 07-31-2009 | 12:07 PM
BigPip's Avatar
It has a burnt smell under the dist. cap. I will be replacing the ICM as these are a common problem with Honda.
It will not run, just turn over.
dracon1000
09-02-2009 03:35 AM
sadbuttrue08
05-24-2009 09:49 PM
dangerousjordan
04-29-2009 05:06 AM
nighthawk5556
04-27-2008 02:14 PM
Noir
09-26-2006 03:25 PM
