99 civic catalytic, eng light
Old Jun 3, 2009 | 08:38 PM
george106's Avatar
Smile 99 civic catalytic, eng light
Hi,
I am new here.
I have a 1999 Civic EX.I need to do the car inspection soon.
Unluckily, the check engine light is on and I get the code it seems to be the problem about catalytic converter.
I went to a place where it only use the computer to do the car inspection.My question is that:
1. If I kill the check engine light with the scanner, and run for 40-50 miles ( I kill the check engine light before, it turn on after several hundred miles) is it possible for me to pass the inspection with the test of computer????
2. If I want to replace the catalytic converter, how much will the part cost?? I ask a mechanic he told me that the part is expensive...But I check online, it seems that for EX the CAT is only about 150 dollars...but for DX or other model, it is much more expensive...
Really need your help.
Thanks a lot.
George
Old Jun 5, 2009 | 07:50 AM
tony's Avatar
Default converter
i did the same thing on my 2000 gmc truck,used a hand held to turn off the light got test done before light came back on and it passes every time.maybe yours will do the same.
Old Jun 5, 2009 | 05:49 PM
Took the accord to the muffler shop, purchased an after market cat, and installed, 75.00 took to the smog shop (Ca) and passed. ( smog orginally failed due to cat blown out).
call around the shops ( no midas ) and get an estimate.
Xgeminix85
May 4, 2012 10:06 AM
mentawai69
Dec 11, 2009 04:04 PM
george106
Jun 18, 2009 09:57 AM
george106
Jun 3, 2009 08:38 PM
datwalka
Jul 19, 2007 07:16 PM
