99 Civic Redline issue
Old Jun 3, 2022 | 10:25 AM
99civic's Avatar
Default 99 Civic Redline issue
I've called a bunch of tuning shops about this issue and here's where I've ended up. I have a 99 Civic coupe and I recently did a factory engine swap with. Along with the engine I converted the car from an auto to a 5-speed. The car now only wants to rev out to 5k RPMs. I tried swapping the computer to a manual trans ECU but it didn't fix the problem. I was hoping a tuning shop could flash the system and simply raise the redline to the proper RPMs but no one I've talked knows anything about these older civics. Thoughts? I would like to go about this as cheaply as possible as it is just a stock car at the moment. I was hoping to avoid having to buy expensive tuning software that would be overkill for what the car is capable of in its current state. Thanks in advance.
Old Jun 3, 2022 | 08:46 PM
welcome to the forum. when you swapped out the engine, did you get the ecu with the same donor car. also you mentioned you changed out the ecu, was it from the same comparable years.
Old Jun 3, 2022 | 09:49 PM
99civic's Avatar
Thanks for the welcome ! Initially I kept the factor ECU from the car in the car. Then upon realizing the redline issue, I swapped the ECU for a manual trans one of the same year. The problem remained.
Old Jun 3, 2022 | 09:53 PM
Sounds like you are going to need to do a tune on it.
Old Jun 3, 2022 | 10:17 PM
99civic's Avatar
Can you be more specific? I'm aware that some tuning will likely fix this, but I'm unfamiliar with Honda in general so I don't exactly know where to start or who to talk to. I mean I'm on a forum for crying out loud...
Old Jun 4, 2022 | 12:07 PM
Call shops that do performance work for crying out loud.
Old Jun 4, 2022 | 12:26 PM
99civic's Avatar
You really didn't read the original post did you? Literally the first sentence says that I called tuning shops and this is where I ended up. I mean if you have a performance shop you think could help me out feel free to drop their name and number and I'll call them.
Old Jun 4, 2022 | 01:33 PM
If there are no programmers that can do it for you I would say that's the end of the story.
Richard98
Jul 10, 2014 11:20 AM
newyork
Oct 29, 2013 11:31 AM
andrewkirschbaum
Feb 17, 2013 09:21 AM
joshbuskirk
Jan 19, 2009 08:56 AM
