Bizarre Flasher Problem
Hey all,
So I finally thought I would join, because after so many threads I've seen, on here and other forums, I could never discover the answer to the bizarre flasher issue I'm having on my turn signals. All wiring is correct, bulbs work, fuses replaced, etc.
Long story short, my turn signals work just fine during the day. However, when I flip my lights on at night, obviously my turn signals stay illuminated. But, when I try to use either the left or right turn signal, it won't flash. It shows its flashing like usual in my car, just not the front turn signals. They just remain illuminated.
And I've never found a single forum or an answer on every Google search you could imagine. Thus, why I'm here.
Bought a new flasher relay. Solved hyper flashing. But not the signaling issue.
It. Does not. Make. Sense.
Hey all,
Yes it works fine. I've seen how that's a common issue too. However like I mentioned, they flash fine when Parking Lights are off. But when they're on, the signals illuminate, but won't flash when I signal.
One thought was having the 12v and Intermittent crossed, but if that was true, wouldn't they not even flash when the Parking Lights are off?
I even have electronic relay as well.
How unfortunate lol.
