Clicking/Popping Sound When I Turn Left or Right?
Old Sep 10, 2015 | 04:48 PM
scanner737's Avatar
Default Clicking/Popping Sound When I Turn Left or Right?
Just noticed this today but I'm hearing a light, one off click/pop sound when I turn my steering wheel a certain amount in either direction. Like if I'm turning to pull into a parking space, I'll hear the one off click/pop once I turn the wheel to a certain degree. It doesn't seem to matter if it's left or right, it happens on both. It sounds like it's coming from right behind and under my or the passenger's seat when it happens, as well, but can't be sure.
It's a bit disconcerting considering I'm on vacation and 200 miles from my mechanic. I'm set to go back tomorrow, but does anyone have any idea of what it could be?
It's a 2005 Honda Civic EX, 165,000 miles.
Old Sep 11, 2015 | 04:51 AM
cv on your drive shafts. getting worn, see if the rubber boots are leaking greese out. get them checked (changed) when you get back.
Old Oct 5, 2015 | 10:20 AM
scanner737's Avatar
Thanks for the reply, ACmech. Wanted to check back in with an update since I thought about it for a second. Basically there was nothing wrong in my situation. Must have been a temporary issue brought on by the rain as it seemed to have disappeared by the evening once it had a chance to dry out. No idea why it happened as I haven't heard it in the rain since then but whatever it was is sorted.
Old Oct 22, 2015 | 02:15 PM
wagonguy's Avatar
Steering rack and pinion could also be the issue. Especially if it's the same spot every time. Or your tie rod(s) are going out
Good luck
Old Oct 24, 2015 | 06:49 PM
Most likely CV
Old Oct 29, 2015 | 06:32 PM
lowlife9's Avatar
i completely concur its your CV joints you can can crawl under the car and inspect the cv boots there most likely damaged and leaking grease.
Red Jacket
Oct 5, 2011 04:33 AM
dgc2009
Jul 16, 2009 02:41 AM
mike0094
Mar 27, 2009 04:01 PM
jCaccordowner
Mar 26, 2009 04:13 AM
a553487
Sep 18, 2008 06:29 AM
