coil spring
Old Jan 4, 2009 | 12:34 PM
semkruse's Avatar
Default coil spring
I Have civic 1998 Lx and when i make a turn driver side i think upper control arm is touching the coil spring can someone help me please
Old Jan 5, 2009 | 04:15 PM
Default RE: coil spring
welcome to the forum, Have someone turn the steering wheel for you and see if you can see what the control arm is rubbing up against. If this is happening, there is something in the steering system that may be worn out, or has the car been in and accident and not repaired properly. Also going to a wheel alignment shop will also tell you what may be the problem without much cost,Have them look at it and adivise you. Should be not cost.
HitchAnything
Mar 10, 2014 01:13 PM
jdmb16ek
May 6, 2013 03:52 PM
SenSin
Apr 7, 2010 09:51 AM
jepoy-honda
Oct 30, 2009 04:36 PM
BlkAccordCoupe
Dec 12, 2006 02:43 PM
