CRX brakes
Old Jun 29, 2006 | 11:23 PM
paulseaside's Avatar
Default CRX brakes
Hi you all
I just can’t believe the trouble I’m having with this 91 CRX si. I’m trying to change the front disk pads which usually is a very simple procedure, right? But on this CRX it’s murder. Normally, a regular C-clamp is sufficient to press back the caliper’s piston to allow the new thicker pads on. But I can’t press the piston back.
The bleeding screw on the caliper's rusted on tight, so I loosened the brake line screw instead thinking that maybe it's the fluid pressure, which doesn't make sense, but oh well. But that didn't work either anyway.
Anybody with any suggestions?
If anybody has the answer, thanks in advance, Paul
03accordex
Apr 3, 2008 04:08 PM
newhonda
Dec 9, 2007 05:37 PM
melissa777mo
Nov 4, 2007 04:57 PM
melissa777mo
Aug 17, 2007 10:53 AM
Dexter1
Jul 19, 2007 07:39 PM
