d15b???????
Old Jun 6, 2009 | 04:18 PM
harper1709's Avatar
Default d15b???????
i recently put one of the rods through the block of my D15B v-tec motor...Is it possible to take the head off this engine and put it on another block?Does the block have to be v-tec or can i use any one?
Also will any engine fit in my 93 civic LX?
Old Jun 10, 2009 | 03:42 AM
welcome to the forum, you should get a v-tec lwr block, go to wikipedia.org and look up honda civic. it will give you all the years and vtec blocks you can use.
Old Jun 16, 2009 | 10:22 PM
91haydenSI's Avatar
i had the same problem with my 98 civic ex. no as long as the block is a d-series anyblock should bolt. to be safe stick with a 1.5 though. the vtec sylanoid is located in the head it is basically an extra over sized rocker that takes place in the higher rmp and over powers the 2 smaller ones that are ingaged in the lover rpm's. and if i remember correctly rockers and cams and valves are in the head. so no you do not need a vtec block to answer your question.
civhatch91
May 27, 2009 12:40 AM
Civic maniac
Sep 22, 2008 10:53 PM
pugads650
Mar 20, 2007 08:51 PM
XHONDAX
Mar 19, 2007 08:39 AM
greendolphin
Oct 23, 2006 10:07 PM
