distributor conversion help mine is different
Old May 3, 2007 | 03:50 PM
hiddenramza's Avatar
Default distributor conversion help mine is different
hello i have a prob converting from obd0 to obd1 distributor
i have a 1991 honda civic hatchback dx.i have a new motor
harness that came out-of a1990 crx single cam non-VTEC.
the prob is that the factory distributor plug is a 5 wire pluge
that looks like this
i would like to make a conversion that looks like this
[IMG]local://2724/49D966EA88894C9E9CDB9AF0C4E3661F.jpg[/IMG]
Old Jun 21, 2007 | 06:06 AM
mike95691's Avatar
Default RE: distributor conversion help mine is different
just go to a junkyard and cut the wire that fits the distributor and tape it up try and see if it works.
Old Jul 2, 2007 | 06:10 PM
josh2113's Avatar
Member
More info on what kind of swap would probably be helpful.
It sounds like your either putting in a SOHC VTEC from a gen 5 civic or you did the mini me swap with a gen 5 head either way if you haven't converted your whole car over to OBD1 then your not going to get it to work. There are ways around it by installing a PM6 module out of a 88-91 civic si or ex with the d16 motor. You are also going to need the distributor, injectors and resistor pack of said SI or EX. Check out this site it will help you do what ever it is you are doing. Go to the How To's section And I'm sure you'll find what you are looking for.dx wiring for PGMFI
Hope this gets to you sooner than later good luck.
JoSh
Old Jun 19, 2021 | 03:33 PM
Yeah the reply was super late and I found answers else where all those years ago. Found out i have a mini me zc vtec, I bought the car running and when I got it home 2 days later all the wiring was burning melting off. Bad conversion. I ended up buying a distributor from someone here or on another forum orders OD0 to OBD1 ECU kit and someone showed me how to re pin it and it ran on first try. Thank you for trying though.
Russellbd16y8
Jan 26, 2017 10:34 PM
cturl69
Mar 1, 2014 09:54 PM
r1forever80
Aug 5, 2009 09:47 PM
Philiponya
Jun 18, 2009 10:07 AM
tubbed_honda
Oct 30, 2006 11:10 AM
