Engine light on, how to turn it off ?
Old Sep 12, 2006 | 01:10 AM
khmer_civic's Avatar
Default Engine light on, how to turn it off ?
hi , i' am new in the ferum, hope no ? is stupid question.
i have 95 civic hb, is there a trick on how to turn engine light off ?
your help is much appreciated. they won't let me pass the DEQ with this light on.
thanks
Old Sep 19, 2006 | 04:16 PM
jefF4i's Avatar
Default RE: Engine light on, how to turn it off ?
First of all, why is the light on? There could be an important reason for it to be on that you should take car of. That being said, disconnect your negative battery cable for 15-30 seconds. That should clear your ecu and reset the computer and your engine light should not pop up again for at least a few miles. If you need the light permanently disabled, the easiest way is to take out your instrument cluster and pop out the light bulb.
Old Oct 3, 2006 | 06:14 AM
BlackJack's Avatar
is it still on with engine off?? cud b wiring connection probs. pretty easy, just send it to workshop n it's done.
gud luck.. or reset ecu like the orther fellow memebr's advise
Old Oct 3, 2006 | 11:30 AM
andy type r's Avatar
hi,i take it you havnt just fitted a decat pipe or anything like that which will also cause the same problem.
Andy
tobie coker
May 14, 2011 03:43 AM
vilfredo
Mar 7, 2009 11:00 AM
hondacheeznoz
Sep 29, 2008 01:37 AM
03hybrid
Aug 28, 2006 07:13 PM
