Help on front driver-side noise 98 civic!
Old Aug 31, 2010 | 10:51 AM
mminney's Avatar
Default Help on front driver-side noise 98 civic!
Hi guys, recently i had a wobbling/rumbling in my front end... brought it to a shop and they replaced the hub bearings in both sides, after doing so my car developed a squeaking/grinding sound. my breaks were pulsating as well. i replaced my half shaft and got new brake pads and roaters, but the noise hasnt gone away. the noise only happened when i stopped but now its when im turning at slower speeds. its embaressing. it started as a squeak or bird chirp sound. then it turned into a pulsating grinding with the squeak.... any ideas? it still makes noise, but the pulsating brake went away.
Old Sep 1, 2010 | 03:24 AM
check the backing plate, it may have been bent into the rotor by error.
Old Sep 20, 2010 | 10:34 AM
mminney's Avatar
nope. it's not the brake plate. i checked it and bent it back. its starting a knocking sound too.
Old Sep 23, 2010 | 04:28 AM
if you had rebuilt half shafts installed, sometimes it could be the problem. not all places know how to do the bearings properly. lift one side of the front and place it in drive, one axle will turn while the other is on the ground, and you can listen for the noise. be careful that the rear e brake is pulled and chocked so the car will not move. do not run to fast, only enough to listen to the noise. Then do the same for the opposite side front to listen for the noise. Or if you have a
Old Sep 27, 2010 | 11:43 PM
mrthought's Avatar
You probably just have a rock caught in between what's supposed to keep debris off your shafts and the shaft itself. That is if the noise happens and/increases as you drive. Get under it an give it a couple fingers.
__________________
Casino Directory
casino tropez
Old Oct 7, 2010 | 11:15 AM
xmechanic's Avatar
Pull off the rotor on that side and grind/ sand off the rust on the face of the hub, also do the same on the inside of the rotor where it will contact the hub. Clean it really good so it's nice and smooth and even, then apply some antiseize to the face of the freshly sanded hub. Reinstall rotor, caliper bracket ( make sure the pads move freely in the bracket, clean up as needed). Reinstall the wheel and hand torque to 80lb. Test drive.
CivicMindedWoman
Dec 8, 2010 07:33 AM
Retrac99
Jun 9, 2009 09:59 AM
nazz
Feb 28, 2009 12:57 PM
juco
Nov 24, 2008 05:43 PM
LTS
Mar 23, 2008 07:12 PM
