help needed with removal of my control arm
Old Jan 11, 2007 | 08:57 PM
papic03's Avatar
Default help needed with removal of my control arm
I have a 98 honda civic and i am having the hardest time removing my control arm. The bolts on here are seized up bad and wont budge at all and some of my bolts broke off and stripped. So does anyone have any suggestions on how i can remove them or how did you remove yours if you had a similar problem
Old Jan 12, 2007 | 03:12 AM
Razorbacksfan88's Avatar
Default RE: help needed with removal of my control arm
if u know have a mechnic who u might be close with have them losen the bolts for with an air gun otherwise im not sure
Old Jan 12, 2007 | 09:05 PM
papic03's Avatar
Thanx ive tried that and it jus snapped off my bolt lol
Old Jan 12, 2007 | 09:15 PM
mopar's Avatar
somtimes they just get messed i suggest breaking them and replacing the bolts
Old Jan 13, 2007 | 02:57 AM
yeah that what i was gonna say next
Old Jan 13, 2007 | 03:32 PM
papic03's Avatar
Thanks i got them off ihad to grind them completely off and replace the bolts
Old Jul 6, 2007 | 08:12 PM
lavender02's Avatar
halow there, I'll try to research on that on the net..I'll send it you asap...good luck
Old Jul 6, 2007 | 08:23 PM
lavender02's Avatar
Hello there, I've asked a friend who had similar problem with his Honda control arm, hope this one will help you... 1. Check alignment and document the readings. Calculate the amount of camber change needed before proceeding.
2. Raise vehicle by the pinch weld, support with jack stands and remove the tire and wheel assembly.
3. Remove the cotter pin and nut from the upper ball joint. Break the taper between the upper ball joint and spindle and remove the ball joint stud from the spindle.
4. Remove the bolts holding the upper control arm to the body. Remove the upper control arm.
5. Make note of the indexing marks on the base of the ball joint and the control arm. Remove the snap ring (if present) holding the upper ball joint in place then remove the upper ball joint from the control arm.
Good luck and all the best!
m.e.greene
Aug 24, 2019 01:36 PM
joe
Feb 3, 2018 04:36 AM
rupenzelleo
May 9, 2015 05:48 AM
1989prelude
Apr 1, 2015 10:41 AM
sferrie
Feb 24, 2012 09:26 AM
