hesitation- civic- gsr
Old Jul 14, 2009 | 05:44 PM
RossT's Avatar
Angry hesitation- civic- gsr
this is a long explaination for my problems, that should probably have an easy answer.
my 96 civic has a gsr swap. months later my distributor took a dump, so i bought a new distributor from distributor king, which has like a 99% positive feedback. when it came, it had the wrong connector on it(could have been my fault, i dont know), so i spliced in my old connector. it ran, but had a hesitation. i gave it to my friend he said that i had swapped 2 wires. so he fixed it, and great success, my car ran great again. until recently......
it now has developed a hesitation again, it doesnt happen all the time, just most of the time. it threw a P0135 code, front o2 sensor obviously, but my question is,
CAN THIS O2 SENSOR MALFUNCTION CAUSE MY HESTATION OR SHOULD I GO BACK AND RECHECK THE HARNESS/DISTIBUTOR ?
i already have replaced, distibutor(questionable), wires(honda brand), and plugs(ngks, stock gsr plugs, exspensive as hell). and i cleaned the hell out of all my grounds, and used new bolts. help me please.
Old Aug 6, 2009 | 02:06 PM
91haydenSI's Avatar
Welcome to the forums and yes the O2 sensor can cause the hesitation but if it started when you replaced the distributor double check all the connections make sure they are okay if they are check the voltage regulator sometimes that can cause a little hesitation but i'd still get the O2 sensor replaced.
Gorillamo
Aug 5, 2011 10:13 PM
atrain33
Aug 4, 2011 07:05 PM
jkl2455
May 14, 2009 05:09 PM
BPShunter
Feb 12, 2008 03:18 AM
kurooakami
Feb 8, 2007 01:00 AM
