Lost spark n gas at once
Old 06-07-2007 | 10:02 PM
ROBY17233's Avatar
Default Lost spark n gas at once
I have a 97 Civic DX coupe, it was running perfectly. I was going down the road and it shut off and wouldn't start. I lost power to the fuel pump but tested the pump and its fine i lost spark and my main relay quit clicking on ignition. I checked EVERY fuse and replaced the main relay but still in the same situation. I have power to EVERYTHING else but whats mentioned above. Any input would be greatly appreciated
Old 07-02-2007 | 08:06 PM
josh2113's Avatar
Member
Default RE: Lost spark n gas at once
Did you use a spark tester? Did you check for a noid (are your injectors getting power)? Either your distributor died or you have bad crank or cam sensor depending on the set up.
Old 07-03-2007 | 05:38 PM
how many miles you got on the 97, and when was the last time the timing belt was changed or checked?
Dave2
05-26-2008 05:03 PM
cchoff
06-07-2007 04:52 PM
frogate
11-30-2006 09:27 PM
trimsaran1
10-03-2006 07:25 AM
trimsaran1
09-18-2006 06:36 PM
