Lost spark n gas at once
Old Jun 7, 2007 | 09:02 PM
ROBY17233's Avatar
Default Lost spark n gas at once
I have a 97 Civic DX coupe, it was running perfectly. I was going down the road and it shut off and wouldn't start. I lost power to the fuel pump but tested the pump and its fine i lost spark and my main relay quit clicking on ignition. I checked EVERY fuse and replaced the main relay but still in the same situation. I have power to EVERYTHING else but whats mentioned above. Any input would be greatly appreciated
Old Jul 2, 2007 | 07:06 PM
josh2113's Avatar
Member
Default RE: Lost spark n gas at once
Did you use a spark tester? Did you check for a noid (are your injectors getting power)? Either your distributor died or you have bad crank or cam sensor depending on the set up.
Old Jul 3, 2007 | 04:38 PM
how many miles you got on the 97, and when was the last time the timing belt was changed or checked?
Dave2
May 26, 2008 04:03 PM
cchoff
Jun 7, 2007 03:52 PM
frogate
Nov 30, 2006 08:27 PM
trimsaran1
Oct 3, 2006 06:25 AM
trimsaran1
Sep 18, 2006 05:36 PM
